- dennych1ExplorerWhat tank heater did you use
- phemensExplorer
deltabravo wrote:
BattleBorn heat pads
Nice, but very expensive $220 for essentially what the waste tank heater does at 1/5 the price (I guess you'd need one of the Battleborn heaters for each battery, for me that would cost over $1200!) - phemensExplorerI have. I added a waste tank heater stuck to a thin aluminum plate. That goes directly under my 6 LiFePO4 batteries. I also have a battery temperature probe attached to my Victron setup to prevent charging if the temp goes below 5C. Batteries are surrounded by foam board insulation.
I considered the grip heating pads, but the waste tank heater has the automatic temp kick in, so I went with that instead. Seems to work very well. It draws down roughly 6 amps per hr and comfortably kept the batteries 10 degrees above ambient. I didn't get a chance to measure under colder conditions as our season wrapped up first. - folivierExplorerSomeone I know used motorcycle or snowmobile grip heating pads.
- Second_ChanceExplorer IIYes. I have Battle Born LiFePO4 batteries and just used their thermostat-controlled heating pads. Not cheap, but very easy.
Rob
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,398 PostsLatest Activity: Dec 28, 2025
