jjrbus
Jul 20, 2020Explorer
theoldwizard1 wrote:
Fans are CRITICAL if you are putting a generator in a box.
I had cobbled a box together 4 years ago and used muffin fans. Was not impressed with them and changed to a radiator 7 inch fan. worked great. However the box stuck out too far and was too low.
Making a new box now and trying to do it without a fan. Little Honda is running hot. 93 degree day and unit is running 105, measured under the handle on the case. Likely ok but I am not happy with it and not sure if more air needs to come in or I positioned vents wrong??
The old setup with fan would run a few degrees above ambient.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
