- rrbowmanExplorer
DrewE wrote:
For screw holes in the luan, I'd think plain old spackling compound would work just fine. There's not much flexing going on in the 1/8" hole itself. This has the advantage of responding reasonably well to being sanded smooth once it's set.
If you do want something else, some sort of a paintable caulking compound would be fine. This is one of the very very few places where silicone would be appropriate for use in an RV, even, in my estimation.
Most Silicone is not able to be painted. - BumpyroadExplorerif luan get a tube of plastic wood type material. why use plaster on wood? and silicone would be dreadful.
but removing the shades permanently would be a silly idea, closely followed by painting the walls. JMHO
bumpy - midnightsadieExplorer IIthe rv is only two years old? you,ll knock its trade in value to ??
- SCVJeffExplorerThere is Spackle that says it's elastic
- GMandJMExplorerPainting the RV walls... intresting idea. What's on the wall currently? Wallpaper? Luan?
Never thought of doing that. - westendExplorerNo silicone in walls. I'd suggest to use a resin based spackling paste. For the usual homeowner, a lifetime's supply can be bought at a Sherwin-Williams store for under $10 in one can. This material adheres well to different materials and won't crack or shrink like more common acrylic spackling. It is easy to apply and is sandable/paintable.
- agesilausExplorer IIIspacking or epoxy putty, tho that will be overkill.
- tvman44ExplorerI don't think paint will adhere very well to silicone.
- DrewEExplorer IIIFor screw holes in the luan, I'd think plain old spackling compound would work just fine. There's not much flexing going on in the 1/8" hole itself. This has the advantage of responding reasonably well to being sanded smooth once it's set.
If you do want something else, some sort of a paintable caulking compound would be fine. This is one of the very very few places where silicone would be appropriate for use in an RV, even, in my estimation. - gboppExplorerI thought all RVs are holes that you fill with money? :)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
