RickLight
Dec 20, 2019Explorer III
I recommend you go with a strip or ribbon type.
LEDs are more than just energy savings, they are fundamentally different so let you do entirely different things. Under a kitchen cabinet you want light spread out as much as possible. As you say, bulky fixtures aren't any good either. Tuck it in carefully and you'll see better no matter how bright or dim the fixture.
You can buy whatever cheapy ribbon, or research some really bright stuff. I found some in with Home Depot Xmas lights! How does 1000 lumens per foot sound? This site has it all and at reasonable prices.
https://www.flexfireleds.com/categories/LED-Flexible-strips/High-Intensity-UltraBright-LED-Strips/
They also have mounting strips and diffusers.
And stick with the lumen output rather than comparing to incandescent wattage. There really isn't any reliable conversion anymore. Commercial products are routinely 120 l/w but sometimes half that. Your 40W bulb may put out 400 lumens, but about 250 leaves the fixture. Does it all go where you want it to go?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
