garyemunson
Sep 29, 2017Explorer II
X2 on better fans. Generally, the fans are the cheapest thing the RV builder can find. Remember, the fan is not usually furnished by the fridge mfg. The fridges were originally designed to have an overhead vent (as they were designed before slides were developed). With the fridge mounted in a slide, now the venting has to be done with a second upper wall vent instead of the roof-mounted one. Obviously with this arrangement, the convective air flow is not as good so the fridge company just puts it in their instructions that side wall vent installs will require an add-on fan.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
