Ok so normally we take our crossroads cruiser to full hook up sites. Water pump doesn't get much use. Sometimes we head to local state park for couple nights and make due. For example we don't shower ...
Many times the pump is mounted on a surface that acts like a sound board. Some insulator bushings often help. The 2 hoses hooked to the pump could be transmitting the sound. Some flexible hoses may be in order. In my case, the pex plumbing under the tub was vibrating on the floor structure. I don't care for eliminating all the pump noise. I want to know when it's running, in case of a leak.
Richard
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
