Ok so normally we take our crossroads cruiser to full hook up sites. Water pump doesn't get much use. Sometimes we head to local state park for couple nights and make due. For example we don't shower ...
My Pump was noisy somewhat due to a water line banging on a cabinet near the water heater. I still wanted to do better so I did the following: 1. glued a piece of wood to a nearly matching size piece of ergo foam 2. glued it down to the floor and mounted the pump to it. So it is completely isolated from the floor. 3. then I connected the pump to the to the water system with a flex line so it doesn't transmit pump noise thru the water system. 4. I also put an accumulator tank to take away surges
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
