Golden_HVAC
Jun 16, 2014Explorer
rv2go wrote:
Use this. Then connect a 12v pump to it. Pump directly into your bag.
Use a simple water pump, not like the one used in the RV.
Pick one up at Harbor Freight if you have one.
You should be able to find a 12 VDC pump that has garden hose fittings on it. Or use a 12 VDC pump with 1/2" fittings and buy the correct adapters at your local hardware store. Home Depot has them.
Did you get a tank yet?
Tank-Depot.com
Of course your local Tractor Supply or hardware store might have something that is close by and no shipping costs.
For a full time RV, I was considering a fresh water tank in the towed vehicle, and then go out and fill the 35 - 55 gallon tank while out sightseeing to add another week or two of dry camping between visits to the campgrounds to dump the main tanks.
Fred.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
