nremtp143
Feb 20, 2018Explorer
TakingThe5th wrote:
I would maybe replace the handle with a stained block of wood that used the same screw holes? Nothing that you could wrap your fingers around to pull but something that could easily be used to slide the door sideways.
If I can match the stain, that would be a nice touch. It wouldn't match the cabinet below it and would let you know that the door is different. Thanks!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
