aeejbe
Jun 30, 2013Explorer II
GordonThree:
I’m now subscribed to this thread because I have the same MagnaSine MS2812 that works in tandem with four 6V AGM batteries. I also get RFI - but only on my AM radio stations. My setup was professionally installed, & later was checked over by a second professional.
Do follow up with your results. I’d be very interested in learning if you have any improvement after you ... "take everything apart again and investigate, as well as upgrading the chassis ground wire."
What is your coach?
What is your coach?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
