profdant139's avatar
profdant139
Explorer III
Jul 13, 2016
Magnetic "Door Halfway Open" Holder
Whenever we cook (which is twice a day), we have to open the windows and the door in order to get enough air – otherwise, the propane/carbon monoxide alarm goes off. In warm, dry weather, opening the door is no problem – we just open the front door all the way, we step outside, and we latch it open.
But in cold or wet weather, I would prefer not to have to go outside, and we often don't want the door open all the way. But there is no latch for holding the door open halfway -- the wind blows it all the way open or closed.
So I came up with a crude "Mickey Mouse" solution. I mounted very strong magnets on either side of a strip of flexible steel. One magnet attaches to the bolt assembly on the door, and the other magnet attaches to the strike plate. Here's what it looks like when deployed:
The magnets are neodymium or rare earth magnets, salvaged from old computer hard drives. (I have a friend in the computer business, but I would bet that you can get these things from any local computer repair shop.) The magnets have holes in the mounting brackets; using a drill press and some care, it is possible to enlarge the holes to accommodate very small machine screws.
I used a mallet to flatten out a one foot strip of galvanized roof flashing. I then drilled holes for the magnets and put them on either side of the steel strip:
Note that on one side, I mounted a small piece of wood, just to keep the strip of steel from flexing too much.
I then added a small piece of perforated steel to the inside of the door frame, above the existing bolt assembly -- this is to provide more surface area for the magnet to grab onto:
It was necessary to use a flexible steel strip, rather than something more substantial, because the bolt assembly (on the door itself) and the strike plate (on the door frame) are not exactly in the same plane when the door is half-open. So each end of the steel strip flexes slightly, to deal with the odd angles:
The whole thing can be deployed from inside the trailer: I open the little hatch in the screen door next to the latch. I stick the far end of the holder out onto the bolt assembly. I then attach the near end of the holder onto the strike plate. Here is what it looks like from the inside:
Finally, for storage, I screwed a small piece of perforated steel on the inside wall of the trailer, next to the front door frame. The magnet sticks firmly onto that little piece of steel.
These killer magnets are powerful enough to hold the door in place, even in a fairly good breeze. But I haven't field-tested this yet, so we will soon see how it does in a strong mountain wind.
  • Ahh! Ok, that explains it then. Thanks, I was a bit concerned...
  • The alarm goes off because we rarely run the vent hood over the stove -- we are boondockers, and the vent fan draws some electricity and (worse) makes noise. So instead, we open the doors and windows to provide ventilation. It works!
  • Dutch_12078 wrote:
    Lynnmor wrote:
    Alarms going off, that would be my first worry. What is the source of the gases, and why are they so concentrated that the stove vent can't handle the problem?
    X2! We've cooked meals almost daily in our motorhomes over the years, and I don't recall ever setting off the LP or CO alarms. We have set off the smoke alarm now and then though. ;)
    Because his trailer is tiny. My trailer is pretty small, and the same thing happens. Th CO alarm doesn't sound, but the smoke detector goes off way too eagerly.
  • Alarms going off, that would be my first worry. What is the source of the gases, and why are they so concentrated that the stove vent can't handle the problem?
  • good work, but I just got a Camco doorajar for $1.98.
    OK I made that up. ;)
    bumpy
