GordonThree
Feb 25, 2014Explorer
RoyB wrote:
You will need to install several batteries in your battery bank to handle this very large load even for just a few hours. Also when you increase your battery bank capacity then you also have to increase your ON-BOARD Charging system to be able to recharge the battery bank in the desired time you want to the battery bank to return back to a usable charge state.
Jeff, I missed that part, is this install going in a motorhome, so an extra alternator or bigger alternator is required?
The Magnum has a 125 amp 4-stage charger, but that only works on shore power, not driving down the road :)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
