BoonHauler
Feb 25, 2014Explorer
Just to throw another wrench into the works, I don't think your load center is split (bus wise) the way you might think it is.
It appears to be a (typical) A & B phase bus bar configuration meaning it's A-B-A-B and so on, not A phase on one side and B phase on the other. That's why the main breaker is a two pole breaker.
Edit: You might be right, after studying the manual more it just maybe one side and the other. A simple powered down continuity check will tell.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
