diveman52
Feb 26, 2014Explorer
Ain't gona work
That inverter has a double pole double through transfer switch buildin
The contacts are only rated 30 amps. When you switch over to the inverter it just jumps A & B phase together on the load side so you only get 120 volts period.
Running the AC off it LOL how many batteries to you intend to carry.
I'd suggest at least 4 Trojan L16H might get a few hour out of it.
I just finish a project on a house boat with solar and a 4000 watt Magnum MS-4024
unit with 8 Trojan L16H. They only run around $275 each and up.
I suggest you talk to someone who really know what there doing.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
