time2roll
Nov 30, 2015Nomad
rexlion wrote:austinjenna wrote:Maybe you should create a link that works. Or explain how a jug of, say, 70*F water can freeze sooner than a jug of 40*F water under the same external temperature conditions. That would be an interesting trick; if it worked then maybe we could postpone freezing by adding ice cubes.austinjenna wrote:Maybe you should read. Link
Doesn't hot water freeze faster then cold water? Thats what I was always told
No. You need better references.
https://en.wikipedia.org/wiki/Mpemba_effect
All I see is that the cooler water appears to be more prone to supercooling and so can remain liquid longer. Not really going to apply to a holding tank.
Add the warm water and sleep well.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
