austinjenna
Dec 01, 2015Explorer
austinjenna wrote:
Quote:
austinjenna wrote:
Doesn't hot water freeze faster then cold water? Thats what I was always told
No. You need better references.
Maybe you should read. Link
Maybe you should create a link that works. Or explain how a jug of, say, 70*F water can freeze sooner than a jug of 40*F water under the same external temperature conditions. That would be an interesting trick; if it worked then maybe we could postpone freezing by adding ice cubes.
Sorry about the link not working. I guess if you really wanted to know you could do this thing called google. Its called the 'Mpemba Effect'
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
