MrWizard
Dec 21, 2015Moderator
Dog Trainer wrote:kellertx5er wrote:austinjenna wrote:
Doesn't hot water freeze faster then cold water? Thats what I was always told
No. You need better references.
Jan 9, 2013 - Hot water freezing more quickly than cold water is known as the Mpemba effect. So, why does the Mpemba effect occur? First, all water evaporates, which means that the liquid (water) "disappears" and becomes a vapor, or gas. Hot water evaporates at a much faster rate than cold water.
How is that for a reference. Maybe it is you that needs to check your references:)
Only until the hot water becomes cold water.
At that point the loss of heat, down to the point odd freezing is the same
These thing always get taken out of context
Years ago, a fellow I worked for, said adding creme to coffee made the coffee hotter, because of a chemical reaction between the acid in the coffee and the sugars in the cream
Maybe this is true if both are at a controlled temp and you have an ultra fine temp probe
But it sure doesn't work that way with hot coffee and cold cream from the fridge
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
