Lantley
Jan 01, 2016Nomad
rexlion wrote:austinjenna wrote:austinjenna wrote:
Doesn't hot water freeze faster then cold water? Thats what I was always told
No. You need better references.
Maybe you should read. Link
Maybe you should create a link that works. Or explain how a jug of, say, 70*F water can freeze sooner than a jug of 40*F water under the same external temperature conditions. That would be an interesting trick; if it worked then maybe we could postpone freezing by adding ice cubes.
Hot water can freeze faster than cold. It is known as the Mpemba effect
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
