Mako_Kupo's avatar
Mako_Kupo
massive solar install
hey everyone! it was a cold winter, but I made it through with minimal issues. my yeti lithium 1400 + 550w 12v renogy panels more than covered what I needed through the season. however, it is now time for my permanent install. I did a TON of research and reading over the winter, and I still remember most of it but some stuff wasn't super clear to me.
to start, this will be my basic specs. currently 550w 12v renogy solar panels, upping to 800w in near future. 800w is where it will cap out for this motorhome, unless I want to start covering the sides of it with panels. I bought the tp of the line converter over the summer, but found someone who desperately, desperately(yes, two desperatelys) needed it. I have them a deal on it, since I was more than taken care of power-wise. I am very much a pay it forward person, and help people whenever I can.
that said, I need to know what I need. I have my panels, with the wires coming through the roof cleanly, so that is all done for now. i need a minimum of 600AH(12v) lithium, and the charge controller/equipment to support that. so, moving forward, know that I only have panels for my final build. I need everything else.
I was thinking battle born lithium batteries. they use cylindrical 26650 cells, with a good warranty. price is about $1,000 per 100ah. if you get six of the batteries, its $6,000 but you get the charge controller, inverter, battery monitor, and inverter. there is all sorts of safety built into the batteries. I consider building my own battery bank from lithium cells, but decided I want to live:B.
I would get this
https://www.amazon.com/Battle-Born-Batteries-Journey-Lithium/dp/B07CTYZ38J/ref=sr_1_5?ie=UTF8&qid=1530450271&sr=8-5&keywords=Battle+Born+Batteries
and this
https://www.amazon.com/Progressive-Dynamics-PD4590-Inteli-Power-Distribution/dp/B002OR41YS/ref=sr_1_2?ie=UTF8&qid=1530450380&sr=8-2&keywords=progressive+dynamics+50+amp
I'm hoping thats everything I would need. I already have 6x 120v circuits installed under my insulation, and 12x 12v circuits. its a ton of circuits. my dad taught me - if you have room to dedicate breakers, do it(basically).
will all of these things work together? I think the inverter the battery bank comes with will be not used, right? the PD converter does everything from taking a charge from the solar controller, taking a charge from the alternator, powering both 12v and 120v, and can charge batteries via shore power. there are a lot of parts here, and I just want to make sure I'm not building a fire pit, but a camper instead.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,400 PostsLatest Activity: Jan 20, 2026
