lawrosa's avatar
lawrosa
Microwave off Inverter. Volt drop with 3 batts parallel
Here's a vid of more of my set up. Running micro off inverter to see a better idea of volt drop with 3 batts parallel.
I dont make exciting vids but it shows more or less how I boondock..
I know this vid may not show anything at all as I only had the micro running a few minutes.. Probably a waste of youtube time... lolol
1. Rule one. Waste of time running the Micro off inverter. especially a modsine type. I just dont have enough invert power . You need puresine at least.
To me its a popcorn maker and coffee warmer.
And again as I discussed elsewhere I dont need to use the coffee pot or the toaster oven as I have a perculator and an RV oven.
But I am torn between keeping 12's or going 6 volt.
If I went 6 volt I will probably do away with the truck battery, as it will not be needed.
Plus I dont know the effects of ampdraw from the RV batts down the wire of 7 pin 20 ft of maybe #8 wire.
https://www.youtube.com/watch?v=wz2ttT8fFLc&t=16s
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: May 25, 2022
