SoundGuy
Feb 07, 2018Explorer
azrving wrote:
Youtube isn't working well for me right now but you are saying that your inverter is wired to one rv battery and then pulling from two 12 volt truck starting batteries through the 7 way wire?
The other way around - as I recall the OP has 2 G24 trailer batteries and a third G24 sitting in the engine compartment of his truck ... truck starting battery isn't involved in this. That G24 under the hood he has wired through a 7-pin Bargman - a poor solution when using heavy gauge booster cables would result in far less voltage drop.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
