theoldwizard1
Feb 07, 2018Explorer II
lawrosa wrote:
1. Rule one. Waste of time running the Micro off inverter. especially a modsine type. I just dont have enough invert power. You need puresine at least.
Microwaves work fine with a pure sine wave inverter.
lawrosa wrote:
If I went 6 volt I will probably do away with the truck battery, as it will not be needed.
It has been said here dozens of times, 6V golf cart batteries are your best bang for the buck ! 2 would be good. If you boondock a lot and do not have a method of recharging you battery bank every day, then you should have 4.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
