lawrosa
Feb 07, 2018Explorer
theoldwizard1 wrote:lawrosa wrote:
1. Rule one. Waste of time running the Micro off inverter. especially a modsine type. I just dont have enough invert power. You need puresine at least.
Microwaves work fine with a pure sine wave inverter.lawrosa wrote:
If I went 6 volt I will probably do away with the truck battery, as it will not be needed.
It has been said here dozens of times, 6V golf cart batteries are your best bang for the buck ! 2 would be good. If you boondock a lot and do not have a method of recharging you battery bank every day, then you should have 4.
Yes mister wizard
There was a thread on 6 vs 12. I didnt know there was a voltage drop issue with 6 volts.
Plus that guys post was hi jacked so I started a new one here with a test I did.
Im going to run the batts down to 75% SOC and try my test again with the toaster oven. The micro wave is kind of over my inverter limit..
Its been raining here a few days so when it clears I will test some things more..
Im surprised I even got it to run the first time..
Here is the thread in question where it was discussed...
https://forums.goodsamclub.com/index.cfm/fuseaction/thread/tid/29553808.cfm
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
