cs2kplus's avatar
cs2kplus
Missing Plumbing
All,
I am looking to re-instate my sewer connections. Bought the RV from a fire department. They used as a demo vehicle for safety. They disconnected the plumbing.I do have the sink hooked up tho. So the grey water does flow as it should thru the T shutoff pipe shown.
What do I need to buy to get it in working order? That is - exterior wise for now. I will deal with toilet side later. I know I need a "y" connection of some sort - but don't know what all is involved.
You can see from pic 1 that they removed stuff and covered with wood and screws. The grey water connection works fine. But I am sure something connects to that. In pic 2 it shows wood removed and some small debris in side. In pic 3 is a piece if what looks like a ring that was removed. It was just sitting in the hole with debris. No idea why they just left that? In pic 4 it shows a metal hanger for a good size pipe or hose.
I tried to look online but am confused as to what I really need.
Help?
Thanks,
Wayne
1. Covered with wood and screws
2. Wood and screws removed
3. Plastic broken ring
4. Hanger
  • To start with, figure out exactly the year, make, and model -- see if you can get specs or plans from manufacturer. Or ask again in this forum for owners of similar models -- you never know, but someone might be willing to take photos of the layout and post them here.
    Good luck! I bet you got a smokin' hot deal from the fire dept on that unit. ;)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
