Ropdoc's avatar
Ropdoc
Montana 3735 MK Washer/Dryer install
Hello fellow RVers,
I recently bought the Montana 3735 MK. It is washer ready. But before I purchase the washer/Dryer unit I wish to understand something. I know that I need to remove the hamper in the front main closet and install the unit there. BUT ... what all is needed to be done for this to work right? Do I simply remove the hamper? Slide the Washer/Dryer unit in after pluging in power and place drain hose in the drain? And some how bolt the unit down?
Thank you,
Dave
  • In many RVs pre-plumbed means everything is done like drain, water hookup and power, but not the dryer vent to the outside.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Jan 20, 2026
