DutchmenSport
Jul 18, 2019Explorer
mailman-ret wrote:
... It appears by your photos, that these steps could be significantly out of level enough to cause problems to your travel trailer. ...
The camper was sitting on level ground, on asphalt. The steps are definitely not leveled but extremely high, ... agree. The photo was taken to show how it can be done. Disregard the fact the steps are already on level ground and pointed upward.
Imagine the same set-up though, if that door was along a steep slope where the inserted feet would not reach the ground. By adding the support going straight down, the support could extend downward another couple feet easily, thus providing support to the steps so they are not dangling in the air.
Agree... I've not come up with a viable solution for when the steps are too long and the slope outside the door is uphill, without digging a hole for the feet to lower into. (I'm still working on that scenario). But, for the dangling, hanging in the air, feet aren't long enough, and you are out of wood blocks to put under the feet to support them, this is an alternative.
By the way, thinking about this, you could do the same thing with a 2x4. Just drill holes all the way through ever inch apart. Then you could made a support as long as you want. The goal is to keep the steps from dangling in mid air with no support under them.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
