SlowBro's avatar
SlowBro
Explorer III
Oct 04, 2021
Mount 100lb mini-split condenser to rear wall?
I have a Coachmen class A and want to mount a 100lb mini-split to the rear wall. Is this too much weight? I know some people use a hitch carrier but ours is occupied. And this RV has no square bumper to put mounts on.
I would use one of these wall mount kits. Maybe this exact model, maybe one like it.
https://www.homedepot.com/p/DuctlessAire-9000-36000-BTU-Outdoor-Wall-Mounting-Bracket-for-Ductless-Mini-Split-Air-Conditioners-and-Heat-Pumps-BPC-3LP/205886666
  • jdc1's avatar
    jdc1
    Explorer II
    Lwiddis wrote:
    Without re-enforcement, your plan scars me!
    I won't be driving behind him.
  • It will be 100 pounds when it's stationary. When it's bouncing down the road it will increase.
    Those brackets will probably tear out of the wall.
  • jdc1's avatar
    jdc1
    Explorer II
    Maybe if you through bolted the brackets and run steel plates 4' long across the interior wall to spread the load across 4 studs. Yea....that ain't gonna happen....
  • What's occupying your hitch carrier?
    Might be able to get a shop to weld up something that will hold the air/con and the bikes (?).
    I wouldn't trust the walls. In a house, they drill into the 2x4 studs. RVs don't have anything like that.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,405 PostsLatest Activity: Apr 21, 2026
