AllegroD
Mar 19, 2015Nomad
On our previous coach, we removed the tube TV and installed an LCD. Because it was slight (about 1.5 inches) we surface mounted the LCD on covered, 3/4 plywood and used a piano hinge on the side. Reason we mounted the piano hinge on the side is we did not go to the extent of figuring out how large a bed lift strut we would need for the weight. We did aff a side cinching lock to ensure it would not swing open at the worst of times.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
