lj_cox
Mar 19, 2015Explorer
We did this on our fifthwheel - pulled the old tube TV from the cabinet, used the existing decorative frame from the opening as the basis of a new cabinet door with a sturdy recessed plywood box in the center, piano hinge on one side and latch on the other. The TV bracket is secured with bolts through the plywood so the TV sits as far back as possible. Our printer goes in the space the TV used to occupy.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
