waynefi's avatar
waynefi
Explorer II
May 01, 2026
mounting on exterior walls
I have always been reluctant to mount things like towel bars on exterior walls of a trailer, especially when it involves putting in screws. Am I being over cautious?
  • Just to clarify, by exterior wall I mean the inside of a wall that goes to the outside, not one between the bathroom and living space or something like that
    • Grit_dog's avatar
      Grit_dog
      Trailblazer
      That would be the definition of exterior wall. Regardless of type of structure.
  • On my last trailer I mounted towel bars to an interior wall just using very short sheet metal screws. It worked fine. My question is about doing the same on an exterior wall.
  • I am assuming your talking about interior walls.  there are a few different ways to do it.  to me the best way is to get a stud finder and use painters tape to mark where your studs are then get a towel bar that matches the spacing.  there are kinds where you cut the bar to size.  this way you can use a 1" wood screw, predrill and it will be solid.  the other way is to use some sort of wall anchors and drill just deep enough to ge tthe anchor in and then screw to that.  just look at your wall thickness then choke up on the drill bit or put masking tape on it so you know to only drill untill the tape hits the wall.
    • Grit_dog's avatar
      Grit_dog
      Trailblazer
      Why would you assume interior when they said exterior?
      • StirCrazy's avatar
        StirCrazy
        Moderator
        because people are using suction cups to hang all kinds of things on the outside of the exterior wall these days.  I ahve seen some trailers with bars screwed to the outside.  so its not a given anymore haha
  • Depends on your level of skill and ability to measure accurately. Assume you mean the risk of poking thru with a screw.
    Thats easily avoided with a little measuring and some 3rd grade math.
    just becuase that Temu towel holder comes with 2” screws doesn’t mean those are the ones you can use.
    PS, I need to learn the trick for getting suction cups to stick to textured surfaces….lol
    • way2roll's avatar
      way2roll
      Trailblazer
      Silly me. By exterior walls I thought he meant exterior walls.
    • Lwiddis's avatar
      Lwiddis
      Navigator
      I agree but I’m not fanatical about a couple of additional holes…tape works great
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
