Bill_Satellite
Jan 24, 2017Explorer II
You should be able to make long and short L-brackets that will accommodate most any curved roof assuming you won't need to raise or lower them but are looking for a simple fixed installation. The road side edges will be high and the inboard edges will be low. This is not a problem while traveling as they would still be parallel to the ground or only slightly tilted which would not cause much/any issues while driving or parked. Flat is best if you can make that happen. Sorry, having the ability to tilt the panels is best but if that's not an option, flat is best.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
