Almot
Jan 24, 2017Explorer III
JRRNeiklot wrote:
The roof is curved which means the Z brackets I have will present a problem.
No they won't.
So called "flat" install implies panel conforming to the roof curve rather than having panel perfectly aligned horizontally. Panel MUST have a few degrees slope to drain rain water and dust.
You might have a problem though if your Z-brackets are not height-adjustable or don't let you adjust them to your liking. Make your own as suggested by others, - each bracket of 2 pieces of aluminum angle bolted together to make a Z.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
