Searching_Ut
Jan 24, 2017Explorer
As Almot mentioned, perfectly flat will cause issues with moisture. Rain, morning dew, the morning frost as it melts off etc. Moisture will cause puddles on your panels that will have considerably more of a negative impact on power production than I think most people expect. I've currently got six 100 watt panels on my 5er roof. I made my own brackets out of two pieces of L aluminum stock bolted together for each bracket. The back of the trailer where some of the panels are mounted has both the rounded curve, and a downward slope towards the rear of the trailer. I made the bracket length so that the rearward slope is removed, but kept the curved roof slope for water runoff.
I have 3 panels on both sides of the roof so half are generally somewhat more optimized towards the sun than the other three. It's a compromise, but anything other than auto tracking panels are a compromise, and tracking units aren't really a viable option on an RV.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
