CA_Traveler
Mar 15, 2022Explorer III
Another factor favorable to serial is greater shadow tolerance than parallel. Virtually all panels have bypass diodes that isolate the panel into sections, 3 for my panels. This means that a shadow on a section causes the diode to conduct bypassing that section. In other words the voltage of my panel would be reduced by 1/3 but with full amps. The same effect for parallel would effectively eliminate that panel due to it's voltage decrease.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
