bigdaddy51200's avatar
Feb 01, 2014
My 2014 Challenger 37KT outside TV upgrade
I started my upgrade to the outside TV today. I plan on putting a VIZIO 32 LCD TV and 29' VIZO sound bar to replace the the 26' Jenson TV , Jenson Radio and Speakers . I will also have a TV mount that will tilt down for better viewing.
This is what I started with :
Had to remove the couch in living room
removed wiring access panels behind the couch :
Removed the counter top behind the couch:
Moderator edit to re-size pictures to forum limit of 640px maximum width.
  • Turned out very nice, a superior A/V system to replace the underwhelming Jensen products.
  • tothetrail wrote:
    Way better, that looks awesome!
    Thanks so much for posting all the details.
    It has been allot of hard work but it will worth it the next time we take her out !!
  • Way better, that looks awesome!
  • Well here is the finished product. I'm just waiting on 2 ball joint brackets to come in from KENCO. I couldn't get the old brackets off because they put on with some sort of spline bolt. I contacted KENCO and they are sending me 2 brackets for FREE !!
  • Had to take off the outside hatch so you can access all 8 screws that hold the inner frame to the wall.
    once the screws are out you can pick the frame out from the inside through the top of the cabinet that had the counter top on it.
    Here is a the inner boxed removed .
    I will start my plans on the new box. I will update this as I go .
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
