divebobber's avatar
divebobber
My homemade rear "porch" and steps
Just thought I'd share my rear porch/steps/hitch extension combo that I welded together with my little handy dandy Lincoln 110 wire feed welder. I looked and looked online to try to find something already manufactured to no avail. This allows me to tow my motorcycle or small boat trailer and still use the steps. It's nice to have them descend right next to the ladder so it can be used as a Joe McGee handrail. The hinges are weld-on with zerk fittings for grease. The lowest step is only a few inches off the ground when everything is flat and level but often come in handy when the ground behind is lower than usual.
  • Nice job. Thanks for sharing.
    Just curious, how much does it weigh?
  • Wow....!
    You're the man Divebobber. Thank you for sharing.
    Most "inventive progress" is an improvement or change in someone else's vision, so...., maybe this posting will allow someone else to envision another approach to making "Truck Camping" enjoyable if it's possible.
    An act (building your stand) hard to surpass.....
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
