riven1950's avatar
riven1950
My new fishing rod holder
I just returned from 6 weeks in the Keys so had a chance to test out my new rod holder.
As you will notice it is very similar to the sewer hose mods that many people do. The biggest differences are that mine is made out of 4" lightweight sewer drain pipe, not schedule 40 or fence post, so it is both light and inexpensive. This is a thin wall pipe, purchased at Lowes for about 11.00 ( 10 ft ). End caps were about 2.00. Before painting I sanded down both ends of the cut pipe so the caps would slide on /off easily. The hold on method is simply a 5" bolt with a wing nut.
This keeps my rods out of the way and not broken. I remove the reels and store them in a bag in a storage bin inside. On the end opposite the butt of the rods I have room for small stuff like a folding net.
The tube is fastened to the rear bumper with very large zip ties, rather than bolted or strapped, because it is light weight.
Now no more broken rod tips or rods. Pictures were taken while traveling so the holder is a bit dirty. Looks pretty good when cleaned up a bit.
  • Glad to hear the wingnuts did not back off....I may just have to steal...er borrow this idea.
  • When going to be traveling I just hold the bolt end with pliers and snug up the wing nut. Traveled about 2000 miles so far with no issues.
    I figure the 250lb zip ties are good for several years before worrying about failure / replacing. You are right UV will eventually get them. Luckily mine get very little UV unless I am camping / traveling.
  • that looks great, will the zip ties eventually fail from UV exposure? hate to see you lose your rods that way. i put those 3m utility cord command straps and hooks in my pass through basement to hold my fishing poles.
  • Nice job. I like that you sanded the ends down so the cap would go on and off easier. Great idea using the wingnut....have you had any issues with the wingnut vibrating loose?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,411 PostsLatest Activity: Jun 28, 2026
