Jpbeck1's avatar
Jpbeck1
My version of 10min Tech- couple simple mods
Here are a couple simple mods we did to our Jayco. Each took less then a half hour to perform.
We boondock mostly and with 2 kids have the potential of going through a ton of water quickly. The first thing we did was to replace the shower with a sink sprayer. Works great for NAVY showers. Get in, get wet, scrub up, rinse off.
For some reason water always puddled and ran down the sides of the tube so I got some of that plastic wall corner protector and cut it down to size, and filed away the corners and siliconed it to the tub.
Here is a water pump noise muffler. It's made out of sound board, so it's a little hard to work with, but not impossible. it gets the pump off the floor, and encloses it. We also put noddles around all the pipes that made contact with the walls and floor. It reduced the sound significantly.
Our trailer came with a cabnet door that was screwed in place, behind it was the hot water heater. I installed hinges and a door catch. Simple and it gave us a little space to store small things.
Moderator edit to re-size pictures to forum width limits of 640px maximum.
  • Please do not double post. See any replies to your duplicate post here.
    Thread closed.
    Barney
  • Now you can wash dishes and shower at the same time. Big time saver
  • Yeah that one is. We have about 6 different barrels. That's just the one I used to test it out a few years ago. You can't have enough water barrels in Southern Cal.
  • Since we boon dock for weeks at a time I carry along a 55gal barrel to refill the fresh water I bought a 30 dollar cast iron A/C pump from harbor fright. It drains the barrel in about 5 minutes.
    Moderator edit to re-size pictures to forum limit of 640px maximum width.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Jan 01, 2026
