geoffdaddy
Feb 27, 2018Explorer
myredracer wrote:
Where do you need to staple the luan? If not visible and in a place like a closet or cupboard, I've just used my small pneumatic nailer with 3/4" 18 gauge nails (I have a small & a larger nailer). If you need a little more holding power, you can angle the nails a bit. Or you could use a finishing washer and screw or even just a small #5 screw.
I think the panel will have more than enough holding power with the TV mount sandwiching it to the backer and the silicone around the edges. I'm mainly tacking it down in a few areas around the perimeter.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
