RoyB
Jul 28, 2019Explorer III
Sometimes you may have to just put up a back board first... Then mount your TV bracket to that... You can paint the back board to match your interior décor...
Also I found the MOLY BOLT was far superior to the wing nut bolt for hanging things from a wall. You can remove the screw from the moly bolt but if you remove the bolt from the wing nut, the wing nut drops behind the wall...
google images
Roy Ken
google images
Roy Ken
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
