mobeewan
Jul 29, 2019Explorer
If you use a plywood mounting board, I would recommend using T-nuts properly sized, to mount the TV mounting bracket to the plywood. They would install on the backside of the plywood and you can you use shorter machine screws to mount the TV mounting bracket to the plywood.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
