westend
Aug 02, 2019Explorer
D.E.Bishop wrote:
Using a backer board that is glued and screwed to the wall is a great idea, using "T" nuts to mount the bracket to the board is the best way to go. Two drill bits are required for mounting the nuts, a std bit for the thru hole the threaded nipple goes in and a forstner bit to counter sink the head.
Now on to the bolts to use for added holding power for the backer board, my suggestion is to use Jack nuts. They are specifically designed for thin material and your walls are most likely 1/10" thick and they come in various lengths.
As mentioned, Toggle Bolts(not wing nut bolt) are not really a great idea, they can fall into the wall and they require a much larger hole for installation.
Molly bolts are available for installation in thin material, but are not as good as jack nuts and not as strong. They look very similar and work the same. In some cases you need a special tool for installation, I have installed 1/4"-20 jack nuts using a long cap screw and a nut instead of the special tool. Here is a link to a mfg.
You will find YouTube videos on the use of the jack nuts. When I am doing a similar installation I countersink the flange on the back side of the board just like I do for the "T" nuts. I use forstner bits because they make flat bottom holes and not tapered.
I mounted a 32" LCD to a backer board in my trailer. I chose to drill holes in the board, make recesses in the holes on the back of the board, lead bolts in from the back, and bolt the TV mount to the backer board. It worked slick.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
