robatthelake
Aug 05, 2019Explorer
One thing to keep in mind .Regardless of how your Television is mounted ,if it can move it can vibrate loose. Most wall mounts feature an easily used release bar or a couple of screws to secure the two parts of the mount. If possible unlatch and store the TV on your bed.
I have also found that adding some pipe insulation in the appropriate locations helps to cushion the movement.
And use some Locktite or Crazy glue to secure those Nuts and bolts!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
