BurbMan
Jun 24, 2014Explorer III
What is final finished thickness of the door? I would consider a 1/4" sheet of luanne, cut in half, and a 1/2" foam board. Use hi-temp contact cement to laminate the luanne to each side of the foam, then again to laminate the fiberglas or filon to the outside piece of luanne. That should be plenty strong for a cargo door. Use some plastic U-trim to seal off the edges with silicone or geocel.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
