cannesdo
Mar 24, 2014Explorer
Ivylog wrote:
Nice job and pictures. I have much the same unit and over time my door would hang up at the bottom. By increasing the distance away from the wall on the top R side I was able to get the door to open correctly. Decreasing the distance on the top L (side with the hinge) might do the same thing.
Exactly! That far right wall (along the starboard side of the rig) is not square at all. It's much wider than 90 degrees. I think they put the shower together in place. We had to pull out the top of the starboard side wall connection (my shower is on the starboard side) and push in the lower left corner (where the lower left corner of the door frame and the lower right of the more "port" -- panel connect.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
