brianosaur's avatar
brianosaur
Explorer II
Mar 01, 2019
New dual 6v's. Need some advice plz
So I just picked up two Interstate GC2 6v's from Costco for $94 ea.
The sticker states 210Ah@ 20hrs.
I dont plan on using them for about another month so I will just store them inside so they dont freeze.
I ran them in series on my workbench and get a charge of 12.35
So I assume this is at about 70% capacity?
I have a 40/120a car shop charger. Would it be ill advised to use this to top off the new batteries, or should I just hook them up to my TT and plug it into the house. The TT has a 3 stage converter/charger power center..
Kind of overwhelmed with battery service & maintenance as I go about reading about it. Going into only my second season with my new TT and the house battery from the dealer was a real poc that barely got me through last year.
I know I need to pick up a hydrometer and distilled water eventually.
Any tips would be great for a newb.
  • Don't want to steal the thread but related... I have a voltage meter hooked directly to the battery and a WFCO converter. It reads 13.7 when plugged in to a/c. Sometimes 13.3. It may go higher but those are the readings I have noticed.
    Does that indicate the charge rate? Is it adequate for GC batteries? I don't have GC batteries but was thinking about it.
  • garyemunson wrote:
    Our previous coach had a WFCO and we had no problems with batteries being undercharged.
    Ignorance is bliss :W - fact is just about every WFCO owner, myself included, who has taken the time to actually measure what their converter is capable of report that it never delivers a 14.4 volt bulk charge to the battery terminals - never. :M I turned mine off and instead use a stand alone charger than does. :B
  • Distilled water "eventually"??? Get it now. People have gotten spoiled the last 40 years or so with maintenance free batteries. 6 volt golf cart batteries need frequent re-watering. You might want to consider the watering systems they sell, especially if the batteries are in a location where looking in the top isn't easy. I'd install them now and let the RV's converter do the job it was intended to do. The upside to the 6 volts is that if you keep them watered and the terminals clean they will usually reward you with 7-8 years of service. Our previous coach had a WFCO and we had no problems with batteries being undercharged.
    https://www.amazon.com/Trailer-Electrical-Battery-Watering-Stystem/dp/B00MJUP1SA/ref=sr_1_12?keywords=battery+watering+system&qid=1551472761&s=gateway&sr=8-12
  • Use your shop charger and charge them up. Fully charged they won't freeze but you can keep them inside, it will probably make it easier to charge them anyway.
  • Despite WFCO's claim to the contrary your converter is unlikely to ever deliver a 14.4 volt bulk charge that your two 6 volt batteries in series should see so you're already off to a bad start. Many here would recommend that if you truly care about those batteries that you replace the WFCO with a converter that can properly maintain them.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,387 PostsLatest Activity: Sep 03, 2025
