Old-Biscuit
Apr 28, 2020Explorer III
Need to run a FUSED 12VDC to GAS on/off switch location.
Then run 12VDC wiring from switch & fault light to DC Junction Box and connect to the OEM wires provided at junction box (DC Junction Box on left side of WH Tank looking from rear
If going with a combo unit (gas AND electric)
Need to run CB protected 120VAC to AC Junction Box ---right side of WH Tank looking from rear.
Unless you install and inside on/off switch....then from CB to inside switch to AC Junction Box where you can wire into OEM provided wiring
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
