RoyB
Dec 10, 2016Explorer III
Lance - My small footprint floorplan would do very well with a small hydronic setup. My power drains would be a 12VDC water pump and a couple of 12VDC axial fans being controlled by a thermostat setting. Then I would also have to use some propane to keep the hot water close loop maintaining hot water temps...
My luck the 12VDC drain would equal the 5-6AMPS DC fan drain located in the Propane Furnace haha...
Sure want to get rid of that mess...
Roy Ken
Roy Ken
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
