Hi Pam!
Yes, that plan will work.
If your husband is comfortable doing the installation, by all means go ahead or alternately have a certified technician do the install.
I have used a Olympian Wave6 Catalytic heater for comfort heating for over five years now. I even run it overnight while sleeping. It uses approximately one-third gallon of propane on the low setting with overnight use.
You do need to leave 24 square inches of open window/vent space for sufficient oxygen flow. That is the equivalent of two 24 inch tall windows open 1/2 inch. Follow the instructions that come with your heater.
Hi Don! I haven't died yet from the heater.
