onemilmhz's avatar
onemilmhz
Outside the box ideas for tank covers and tongue storage
Pun intended! A recent thread on another site got me thinking, anyone build a homemade/custom tank cover for their LP's? If so, what material did you decide to use and why? The factory/industry available options just don't impress me much. They're either super cheap and flimsy, like the thin plastic white ones that don't work very well and look terrible; or they cost a fortune. $200+ for a piece of plastic with a door? No thanks. I don't have a garage or other covered space to store my pup, and I have had bad luck with tanks rusting and looking horrible. I'm thinking of building a sealed box of some type around them for protection and a little extra storage, maybe even incorporate the battery. I know there are some redneck engineers out there (or even some legit ones) that have done this, so let's see them!
  • robsouth wrote:
    Not sure a "sealed box" for LP tanks is a good idea. Check further on it before proceeding.
    I should clarify, not sealed as in airtight but weatherproof and lockable. Lots of battery thieves around here. Sealed being bad when it comes to batteries as well. ;)
    This is true, when propane tanks get hot especially when they are full the valve is designed to vent a little pressure off. Propane tanks in the same box as battery's isn't a good idea also since a spark from the battery's could cause a problem when the propane takes release a little pressure.
  • Not sure a "sealed box" for LP tanks is a good idea. Check further on it before proceeding.
  • Way back in our popup days I needed a bit more storage for hoses, cables, etc so I built a custom storage box that I mounted at the rear of the trailer. I built it with plywood, designed a locking capped lid for it, and finished it in black vehicle rock guard textured spray paint. I towed that trailer over tens of thousands of miles for several years in just about every type of weather imaginable and it proved to be completely watertight. There's no reason you couldn't do the same to build a tongue mounted box to the exact dimensions you want, my only caution being that I personally wouldn't put a battery (or batteries) in the same compartment as the propane tank(s).
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
